I have a 2001 banshee. When I am riding it both pipes smoke but the right one smokes more. And the right pipe is hot and the left is only warm. Also its is running pretty slow. I put new gas in it and it helped it a little bit but not much. PLEASE I NEED HELP. :(
Have you tried new plugs. If your carbs are synced, your carb caps aren't leaking air and there isn't any other air leaks, you might just have a fouled plug. Go to your nearest auto parts store and save a buck or two. Have you changed anything recently.
How much is the right side smoking? You may have a shot crank seal and it is sucking tranny oil in..... I would try the plugs first, and then look for the crank seal option. It will smoke alot and smell horrid...
