do they wire up like stockers or do ya gotta cut shit up. i got the ones that mount up like the stock ones up front.
they dont plug right up. i cut the plugs of the stock lights and soldered onto the wires for the trail techs.
just make sure you silicone the lights to the conectors and put it over all the scews too, atherwise everything will come apart and no light. they work pretty good. i havnt used mine too much, but they provide ample light, deffinately better than stock
check out 4 Wheel Parts
They've got an alright selection and they're located all over the place so you can go check out the lights in person instead of just internet shopping. Also as a side note, more wattage isn't a good thing unless you upgrade your stator. A set of 35w lights (same as stock) will outshine a set of 55w lights on the stock stator. I've got some 8" Pro Comp lights in the stock location with 35w bulbs and they do a pretty decent job given that they were only like $35 each. One of these days I'd like to rewind my stator and throw on some 130w bulbs :D
