Biggdogg05 Posted December 1, 2013 Report Posted December 1, 2013 I traded my yzf450 for an 05 shee. Ran like a scalded cat until I let it sit for over a year while traveling for work. Carbs were removed and had zero sludge in them. Sprayed everything clean. New plugs. Fresh gas. But now I have zero spark and never had an issue until it wasn't used for awhile. Like I said I'm a noob to these bikes and have become a full believer in 2 strokes but if anyone can give me a starting point I appreciate it in advance. I have no desire to buy high dollar after market parts currently cuz I plan to tear it down to frame next late spring and rebuild entirely. Thanx again y'all. Quote
KaN Powersports Posted December 4, 2013 Report Posted December 4, 2013 Basics first... What mods? Does it have E-brake, and TORS still? (Is the brake on?) But for starters, check the continuity in the key, and kill switch. Corrosion may be your enemy from a 'sitter'. If you don't want to start with testing, then spray a buttload of WD-40 into the switch and rock it off and on-sometimes that's all it takes Good luck!! Quote
