Hey every one, last night during dirt circuit my bike was running awesome in the first round But in the second race on the second lap it dropped back to 1 cylinder (only running on the left) so I pulled up and spent the rest of the night trying to fix it but not sure what has happened.
The first thing I did was a compression test, both at 140psi still (same as b4 the race)
I thought it was a carb problem (35mm pwk air strikers) but I swapped them around and it's still only the left cylinder running.
Tried new plugs, swapped plug leads still the same.
If a reed petal broke could it cause this kinda thing to happen?
Cheers, Paul
Pull your intake and check the reeds.. it will take literally 5 minutes..
Ok so I have since checked my reeds (looked fine) but swapped them out any way with some stock reeds.
I have also changed the carbys just to eliminate any chance of it being them.
I Started it back up but it's still the same, only running the the left cylinder. The right side pipe just blew out unburnt fuel.
I covered the right side pipe with my hand and after a few seconds the bike starts to rev up, obviously covering the left pipe after a few seconds kills the engine.
Any more thoughts of what else I could check?
  • 2 weeks later...
Figured out no, it is fixed tho, I replaced just about everything, stator, flywheel, CDI, carbys, reeds, and it still did it but the problem did swap sides, then after that I swapped plugs again with plugs I had already tried and it all worked.
So I don't know what the problem was.
