thebloker Posted November 6, 2003 Report Posted November 6, 2003 I have my cases taken apart, and while I was cleaning them up I noticed that there was a bunch of grit in one of the roller bearings in the top of the case. It is the bearing on the top part of the case where the clutch cable connects and actually goes inside of the motor. In attempting to remove it, I managed to rip out the inner part of the bearing and remove all of the needles. The part that is stuck is the outer part of the bearing, as it is flush with the case. I don't want to try to bend this part out as I might nick the case in the process. Anybody have any suggestions? thanks, thebloker Quote
SDD Posted November 6, 2003 Report Posted November 6, 2003 Use a dremel and cut the outer race in a spot or two and it should just fall out. Heat the case up and freeze the bearing when you go to put a new one in. Quote
thebloker Posted November 6, 2003 Author Report Posted November 6, 2003 Dremel, huh? Sounds like a good idea, I can't believe I didn't think of that earlier, thanks! Between school winding down and work, I haven't been able to devote as much time to the quad as I would normally like to. Thanks for your help, thebloker Quote
