sheerider11 Posted July 26, 2014 Report Posted July 26, 2014 Also I have 35pwk. If your having a hard time with stockers and no tors then you need to man up. Quote
d4n1932 Posted July 27, 2014 Report Posted July 27, 2014 How much for the throdle every thing cable lever? And will it work with my stock carbs and thors? I don't want to do the deleat untill I have a problem with it. To my knowledge my carbs are good to go Quote
sheerider11 Posted July 27, 2014 Report Posted July 27, 2014 stock fits. If you remove the tors it will be 100x easier pull. But the Honda is better. I also shave the stop down. Quote
Jereme6655 Posted August 1, 2014 Report Posted August 1, 2014 Order a new cable from a site sponsor.....then lube your cable. Then install said cable. Then put your purse down sally. Man up....its a quad....you're not trying to move the empire state building with your thumb......its two tiny little carbs. If it hurts that bad then god forbid what kind of men we are going to be pro-creating to run this world when we are gone........rant over. Quote
