salmon_slayer06 Posted September 20, 2013 Report Posted September 20, 2013 (edited) The vent was clear on mine, but the seal popped out anyways. I had too much oil in it. I found that the sealant I used caused the seal to slide out. Like some have said.... use no sealant. I wish these were grooved seals. Edited September 20, 2013 by salmon_slayer06 Quote
Jereme6655 Posted September 21, 2013 Report Posted September 21, 2013 woffy.....like said....try a new seal, with an extremely clean surface. And also watch the amount of fluid you put in the trans. Where are you from in Michigan? I ride quite often in Mio. Quote
Coupelx Posted September 21, 2013 Report Posted September 21, 2013 Whats too much oil? I run 2 qts and never popped a seal. Quote
woofy Posted September 23, 2013 Author Report Posted September 23, 2013 woffy.....like said....try a new seal, with an extremely clean surface. And also watch the amount of fluid you put in the trans. Where are you from in Michigan? I ride quite often in Mio. Quote
woofy Posted September 23, 2013 Author Report Posted September 23, 2013 I was jus in mio a wk ago. That's wen my seal popped out. Quote
salmon_slayer06 Posted September 24, 2013 Report Posted September 24, 2013 You guys may want to check out St. Helen. They groom the trails. Its actually the main ORV trail that I ride, goes from Roscommon to southeast end of Houghton Lake. Gotta stash gas cans if you want to do the entire route. Its a rush, beats silver lake any day IMO. Quote
