Give everyone a little background
Bike was running , would kick 1st or 2nd time but wouldn't idle.  Did some investigation and realized my idle screws weren't working.  Opened the TORs box and plastic was broke off inside (reason I couldn't set idle)
I purchased a set of stock carbs on bhq that already had the idle screw drilled and tapped
Unplugged TORs setup(main unit, each TORs box, and throttle switch), removed old carbs, installed TORs removal then new carbs
Bike started but ran rich and then I realized i should check main jet (had 230, put back in 200) needle on 3rd click, a/s 2 turns out,
Bike is completely stock.  here are some pix of setup.  Now I can't get it to fire at all.......hours later I am ready to banghead
Edited by diesel60
I made sure the slots on the side of the slide lined up inside the carb- ..... Just so im not going crazy which slide is supposed to be on choke side? Any distinguishing factor? Thanks
Sent from my iPhone using Tapatalk - now Free
Thanks hoppedupandcutdown - great post.  Im going to add that image to my library so I don't forget....I did go back and verify and they are in correct.  I did manage to get it started with WOT....wondering if I need the slides/throttle cable adjusted.....can't get this tuned in ...
Edited by diesel60
BTW...isn't there a difference on the slides too though that one is on the choke side and one is on the right side?  I confirmed the cutouts are facing filter side.
They will go in the opposite carbs backwards, so if the cut out is at the rear, they are in the correct carbs the correct way.
Good point, I will check that and the pilot jets.  I did clean both carbs out real good before transitioning to the tors removal.  cleaned all the jets, bowls, and needles etc when installing.
