When I hold my clutch in and rev the bike it wants to move forward just a little bit.. also, it feel like there is not enough tension to pull the clutch back into place when I release it.. like i have to push it back that last inch after I shift.. How/what do I need to adjust to fix this?
Not every banshee works off of those arrows...a lot of people on here have said their clutch works fine and arrows are not lined up
The alignment of the arrows is for the pancake bearing set screw, not the cable adjustment at the perch.
When aligning the arrows, the clutch cable end shouldn't even be in the lever, per spec.
