bashee crazy kidd Posted November 4, 2003 Report Posted November 4, 2003 im wonder if it gives u a good power rang for the bottom end Quote
bignasty1 Posted November 4, 2003 Report Posted November 4, 2003 i would recomend a noss head over the hemi the noss heads look better no matter what style you get and on how it affects you power wise is a matter of which domes you go with but i still recomend a noss over the hemi any day even tho i havent delt with one b4. Quote
. Posted November 4, 2003 Report Posted November 4, 2003 all banshees are hemi's, the name is just a gimmick. It stands for hemispherical combustion chamber with the plug being in the center of it. Only head thats going to make a difference over a nosshead/pro design head etc is a head that has turbo domes in it, that presumably spins the intake charge to mix the fuel and air better......I say if it aint mixed by the time your crank stirs it around and it goes through the transfers and into the cylinder your not gonna get it much more mixed. Quote
bashee crazy kidd Posted November 4, 2003 Author Report Posted November 4, 2003 how much are those? Quote
dlnoss Posted November 4, 2003 Report Posted November 4, 2003 Yea, hemi is just a buzzword that makes it sound like it's something different. I am experimenting with some domes that don't have hemispherical chambers. All the tests so far are very impressive. I have only let a couple of engine builders have them at this point but will probably put them on the market them pretty soon. Quote
BansheeBrian Posted November 5, 2003 Report Posted November 5, 2003 I am anxious to see how you new product will work! Quote
