Fast_quad_03 Posted August 22, 2013 Report Posted August 22, 2013 My 4 mil is blowing coolant out the overflow for no reason. It will do it at cold temps, and sounds like its boiling, but itll only be 180°f so i know it's not overheating. But it does seem to get hot real fast. It's jetted right, which has me real confused. Not sure what else would cause this? Quote
S10RACER Posted August 22, 2013 Report Posted August 22, 2013 Pull your clutch cover. I bet you broke your clutch basket and that took out your water pump Gear. I just had the same thing happen to mine. Quote
sleeper06 Posted August 22, 2013 Report Posted August 22, 2013 Head gasket ,leak down the motor Quote
Fast_quad_03 Posted August 22, 2013 Author Report Posted August 22, 2013 The head gasket makes since. But I don't see Why it went bad? It's a month old, and there is no coolant in the cylinders Quote
