  • Replies 40
  • Created
  • Last Reply
Top Posters In This Topic
This is why there are people who do this shit for a living. Figure out your squish and call noss machine or whoever gets you hard and discuss it with them. Profit with something not half assed.
You do know that there are people that do this for a living and still dont know how to calculate ratios right?
I got it back together last night. Now I'm at 150psi on both cylinders. Have a .055 squish. Passes leak down test. I took it for a short street run and it feels stronger then it ever did.
you heard it right here folks. straight from the master. turn off your computers, trade your banshee off for a golf cart and a set of golf clubs.
I don't know how one would classify my motor. I did all the port work myself. If I change my base gaskets then I have to change domes again. I had .015 thick paper base gaskets in it just prior. It changed my compression by 10 psi. So I was at 170 psi. I went back to the .030 oem's and it dropped to 160psi. Replaced the 20cc's with 21's and now I'm at 150psi. Since the bike is running good. I'm leaving it till the next blow up.
You're doing fine. Thats how most builders on this site do it.
