aleyesonme Posted August 8, 2013 Report Share Posted August 8, 2013 Need some advice....I've searched thoroughly and haven't came across an answer so here goes...I recently purchased a cub motor, I'm new to the cub scene, anyway I took the topend apart to make sure everthing looked fine on the inside...I noticed that some rtv was used as the gasket and nothing else. So I had some oem gaskets lying around and used them to put it back together, only to realize later that there's a gasket made for the monoblock cub. So I want to know if the two piece gasket is fine or not.....thank you for any help Quote Link to comment Share on other sites More sharing options...
dajogejr Posted August 8, 2013 Report Share Posted August 8, 2013 Some people run no gasket and just RTV. I prefer the one piece gaskets....but it's preference...not right or wrong. 1 Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted August 8, 2013 Author Report Share Posted August 8, 2013 Some people run no gasket and just RTV. I prefer the one piece gaskets....but it's preference...not right or wrong. Thanks a lot...I feel better now Quote Link to comment Share on other sites More sharing options...
J-Madd Posted August 9, 2013 Report Share Posted August 9, 2013 If it was setup to not run a basegasket, and you put one in there, it's gonna mess the port timing and squish clearance up. 1 Quote Link to comment Share on other sites More sharing options...
trickedcarbine Posted August 10, 2013 Report Share Posted August 10, 2013 ^this. Assemble it with no gasket again and do a squish test to see if a gasket is doable. Quote Link to comment Share on other sites More sharing options...
aleyesonme Posted August 13, 2013 Author Report Share Posted August 13, 2013 ^this. Assemble it with no gasket again and do a squish test to see if a gasket is doable. ok will do guys..thanks a bunch Quote Link to comment Share on other sites More sharing options...
camatv Posted August 14, 2013 Report Share Posted August 14, 2013 one piece will fit much better. if its case matched most 2 piece gaskets wont seal. Quote Link to comment Share on other sites More sharing options...
