I have a 06 banshee, had a rod bearing lock up, chipped the rod, sent it up through the cylinder, and ruind everything, had to bore it 60 over, head is pretty beat up, so I wanted to do a 4mil stroker, and run a cool head, I was thinking about going with vitos crank, but I can't figure out the numbers for which crank goes to what pistons, and havnt found 4mil pistons for a 60 over, and what size domes to run with that if I got the cool head, so any suggestions and help would be appreciated, thanks
get the HOTRODS 4mm stroker long rod (115mm rods) crank, and use Wiseco 795 series stroker pistons
  • Like 1
^^ the spacer plate is not to correct port timing... It is to correct head to piston clearance.... Do not run a spacer! Have it ported and get cut domes for a coolhead...
x2
no better way to do a 4 mil, you HAVE to get port timing corrected of there will be no power benefit at all for spending that money - hell you may even LOSE some. You might as well have it fully ported instead of just "correcting" the timing. Your choice of the port work will give you a choice of the power you want to make anyhow. Stock carbs can support you up to about 70hp - hope this helps
