Diff in alky carb and gas carb
Alcohol and gas require different air/fuel ratios to run correctly. Alcohol carbs are modified for significantly more fuel flow. Alcohol traps moisture from the surrounding air so purging with gasoline is required after use. Alcohol will make 5-7% more power than gasoline when properly tuned so it can have an advantage at the track. To get the most out of it will take some research, practice and domes setup to run it.
Hey Ken
Call Brandon at Wildcard and go from there. He's a great sponsor and has excellent customer service.
I run alky and Brandon set me up with his Drag port & domes and the bike runs great ( unless I fuck up the tune )
The only issue is tuning for extreme humidity. It's a learning process ; but well worth the gains available.
Still waiting on them Spindle mounts :whistling:
Troy
