jsinar Posted July 9, 2013 Report Posted July 9, 2013 I think (hope) it's just my clutch acting funny, if I launch it, it'll pull like crazy, through all the gears, but the high gears, I noticed today that if I'm rolling pretty good in 6th, let off the gas and hit it again, it'll act like the clutch is slipping. BUT.. if I push the clutch lever forward it'll stop. The lever has about 1/2" slack in it, so it's not adjusted too tight. Is it clutches or something else? If I pull the clutch lever and let it go, I can still push it forward a little, and I see the arm on top of the case moving while I push it forward it too. The 2 arrows meet when I let go of the lever, and if I push the lever forward it'll go past the arrow just a little. Is the adjustment in the case not right, or is this normal? Quote
Larry's Shee Posted July 9, 2013 Report Posted July 9, 2013 Lube the cable or might need new one Quote
jsinar Posted July 10, 2013 Author Report Posted July 10, 2013 The cable isn't binding or anything, it moves freely. Quote
