Eat more fast food = More bottom end.
Or try one or all of these -
Drop one front tooth
Add +4 timing
Get some FMF fattys
Get a cool head with higher compression domes
Get your motor ported
Clean your filters
Work on learning to tune your carbs better
Buy bigger motor
Loose weight
Buy a Raptor 700 and do "The big 6 mods"
If you start adding timing and compression you better be sure your jetting is correct. It will have a much better bottom.
