Braxton smith Posted July 2, 2013 Report Posted July 2, 2013 How do I get more bottom end on my bike? Quote
skywalker7374 Posted July 2, 2013 Report Posted July 2, 2013 Compression helps with the bottom end. Have the head milled or throw on a cool head of some sort. Quote
sheerider11 Posted July 2, 2013 Report Posted July 2, 2013 Well what do you have now? Do you have a drag ported 4 mil that you just picked up? Do you have a bone stock bike? 1 Quote
WINDYCITYJOHN400 Posted July 2, 2013 Report Posted July 2, 2013 Eat more fast food = More bottom end. Or try one or all of these - Drop one front tooth Add +4 timing Get some FMF fattys Get a cool head with higher compression domes Get your motor ported Clean your filters Work on learning to tune your carbs better Buy bigger motor Loose weight Buy a Raptor 700 and do "The big 6 mods" Quote
Braxton smith Posted July 2, 2013 Author Report Posted July 2, 2013 Well what do you have now? Do you have a drag ported 4 mil that you just picked up? Do you have a bone stock bike? Quote
Braxton smith Posted July 2, 2013 Author Report Posted July 2, 2013 Pretty much all stock except t5 pipes Quote
skywalker7374 Posted July 2, 2013 Report Posted July 2, 2013 throw on some stock pipes, Im sure they have some good bottom end. Quote
Braxton smith Posted July 2, 2013 Author Report Posted July 2, 2013 Is there a different way I can because I love my toomeys but I still want to have a lot more torque Quote
dozer Posted July 4, 2013 Report Posted July 4, 2013 Judging by the responses, its a good thing u didn't come out and say you don't have enough down low. Quote
Uf21 Posted July 4, 2013 Report Posted July 4, 2013 Get 916 pipes and get a timing plate with +4 timing. Quote
trickedcarbine Posted July 5, 2013 Report Posted July 5, 2013 Race fuel, new domes( re chamber the head) and 7 degrees of timing. Quote
dozer Posted July 5, 2013 Report Posted July 5, 2013 If you start adding timing and compression you better be sure your jetting is correct. It will have a much better bottom. Quote
