Free yellow banshee Posted June 29, 2013 Report Posted June 29, 2013 My banshee has the following mods.... Dune/play port Fresh bore/hone T5 pipes 4 force 4's Cfm airbox with k&n's Boss intake Dynatek Cdi Stock carbs Passed the leak test The carbs have been cleaned in my sonic cleaner and the choke tube is installed. I have 310 mains, 27.5 pilots, air screws at 2.5 turns out and stock needles in 3rd slot. I got it fired up and was trying to dial the pilot jet in. It sounds pretty good and revs clean with no noticeable flat spots. The thing that concerns me is I can turn the air screw all the way in and it make no change in the idle. I can also open them all the way up and no change. After all the reading I've done I figured I would be at 27.5. I don't have any 30's right now, but looks like I'll be ordering them. The main will be easy cause I'll plug chop it and I'll be able to feel the needle. I know how to jet these carbs, but I've never seen one where the air screw makes no difference. And yes I gave the motor time to catch up to the adjusted mixture. Thanks Quote
badassbanshee479 Posted June 30, 2013 Report Posted June 30, 2013 Sounds like the slides are to high causing the motor to run on the needle rather than the pilot circuit Quote
Free yellow banshee Posted June 30, 2013 Author Report Posted June 30, 2013 Good point. I will check that. The idle screws work fine though. And the idle is set. Quote
Free yellow banshee Posted June 30, 2013 Author Report Posted June 30, 2013 Any other suggestions? Should I order some 30 pilots? Quote
WINDYCITYJOHN400 Posted July 1, 2013 Report Posted July 1, 2013 Yes. The V4's like one size larger pilot than normal. So I would start with a 30. Quote
Free yellow banshee Posted July 1, 2013 Author Report Posted July 1, 2013 Sounds good man. Thanks. I have 32.5 pilots now. I'll try them first. If it's to rich I'll order 30's. Quote
