If that's a Blaster axle, it's definitely an '03 to '06. You can tell by the place where the brake disc mounts. Measuring the overall length will tell you if it's the narrower Blaster axle. However... The splines don't look to be in very good shape on that one.
The '88 to '02 Blaster axles have a collar that's a permanent part of the axle that goes against the right carrier bearing and is the seal surface. The rotor is on a floating hub that slides on over the right end of the axle, so there's no shoulder to the right of the splines like Banshee and late Blaster. Early Blasters have a fixed caliper and a floating rotor. I would never run a floating caliper and a floating rotor. (Early Blaster axle in a Banshee)
Edited by Starwriter
