i used a uni bit going from 3/8's to 7/8's dont over ream it, or your front end will be sloppy, reem a little then check the spindle and joint for fit, reem a little more and so on.....
  • 1 month later...
Thought I would post some pics of the finished product for you guys. What we have is the stock a-arms modified to accept aftermarket ball joints. I found a source for the joints that did not require the spindles to be reamed. My buddy did the fab work, as you can see he is an awesome welder. If you are interested in having this mod done he has all of the jigs to do it.
