stock spindle stem size?
mrgreene
I just got new arms and hiems,replacing the old LS arms.The old ball joint stud is 14mm@ top and 12mm@bottom,my new heims are slightly small about 11mm and 13mm.I know it doesnt sound like much but they are hella loose! I have been reading about reaming and wonder if this may have been done to my spindles.I was searching for new ball joints or heims but having a hard time getting correct stem/stud size so i was thinking if my spindles had been reamed maybe it would be cheaper to just buy used factory spec spindles instead of a whole new set of joints? Any thoughts or maybe a measurment of the factory spindle stud hole to compare to mine?.....purdy plssss!
