Bondo Posted October 31, 2003 Report Share Posted October 31, 2003 somebody told me that the little plastic piece held on by the Main Jet (I think it's officially called the "Splash Guard") can be removed for more fuel flow. Of course, then you have to jet down on your main. Anybody else heard this? Quote Link to comment Share on other sites More sharing options...
sksummers Posted October 31, 2003 Report Share Posted October 31, 2003 I've seen them removed with no issue, it should not change your jetting. Quote Link to comment Share on other sites More sharing options...
skykingcory Posted October 31, 2003 Report Share Posted October 31, 2003 I believe that piece is just to keep the fuel from sloshing around so bad to make sure the jet has a consistent amout of fuel to have access to. The jet has a hole much smaller than the splash guard so I don't think it would make a difference since the jet would be more restrictive. The jet is the limiting part of the puzzle. Even in theory if it did allow more fuel, it wouldn't be beneficial. You have to have more oxygen available to the engine before it would help any. Would be the same as jetting up without doing any mods. Would just make you run rich as hell if it did help, which I don't see how it would. Quote Link to comment Share on other sites More sharing options...
