Derrickc14 Posted May 30, 2013 Report Posted May 30, 2013 I have a 02 banchee with toomy t5's, k&n filter in box - lid/cover off and v force II reeds. Baught it off someone and i just want to do some maintenance before i ride her. I live in pa-sealevel. I need main jet size recomandations for the mods that are on it. Any help for the newbee?. first banshee ever. I did reseach for the past 3days and found some insite on jet sizes that people are running but their mods exceed mine by a long shot. thanks for you Help Quote
tdod101 Posted May 30, 2013 Report Posted May 30, 2013 240 - 260 main 25 pilot Needle middle clip A/S 1.5 turns out Quote
sheerider11 Posted May 30, 2013 Report Posted May 30, 2013 240 - 260 main 25 pilot Needle middle clip A/S 1.5 turns out Way to lean for here. 27.5 260-280. I'm in jersey so I'm pretty close to where your at Quote
badassbanshee479 Posted May 30, 2013 Report Posted May 30, 2013 Toomey sells a different needle for there pipes I would recommend picking a set up... Probably start with a 300 main and do plug chops and lean it down slowly Quote
Derrickc14 Posted May 30, 2013 Author Report Posted May 30, 2013 Thanks boys! Huge help. I will try sheeriders first since hes so close to me. Thank you again Sheerider - what kit should I buy and where? Quote
SpecialEd 05 Posted May 31, 2013 Report Posted May 31, 2013 If you're running no lid and K&N anything under 280 will be too lean. I'd be at a safe 320, seems to be the average size for lid off with 27.5 pilots at 1.5 turns out. With the V-Force reeds you should be dropping the needles 1 clip (leaner). If you have the Toomey needles (6 groove) you should be at the 4th groove from the tapered end. Here is a handy jetting guide. If you scroll to the bottom there is a list of mods where can add up the jet sizes from the mods you have to get a ball park idea of where to start. http://www.dfn.com/agservices/jetfaq.html Quote
