my mods
stock motor with pro circuit pipes, billet intake, pods, V force 4 reeds
altitude is about 660
carb needles 3rd from top
mains are 155
carbs had 48 pilots and ran best with air/fuel screw 3/4 turns out
I installed 50's and it ran best with 1 turn out so I put in 52's and now runs best with 1 1/4 turns out, temps today were 60deg
I was told to raise the clip one by a fellow member and just wanted to get some opinions from others,
just from short runs at 200 yds it runs good, I have not had a chance for longer runs yet and want to make sure everything is OK before I do that..
with the 28's from stock carbs I need to learn how to shift faster because the thing wants to rip.
If its running good ride it.
im betting you a little rich up top. I have similar mods with porting and 155 is about spot on.
