tdod101 Posted May 22, 2013 Report Posted May 22, 2013 So I wanna go faster, I can't really afford to do direct engine work right now, I've spent alot of money on bolt on mods, right now I figure I'm topping out at 60 - 63 mph, I'm running 13 tooth front and 42 tooth rear. What do you guys figure I can do ? Don't get me wrong this thing has alot of snap, but I gotta beat my friend, he has a stock banshee same year 1987 but his transmission gearing is different, no one can touch him Quote
tdod101 Posted May 22, 2013 Author Report Posted May 22, 2013 Forgot to mention, it's quick an has snap but in 5th and 6th gear it's pretty slow, that's where my buddy will blow right past me Quote
possum Posted May 22, 2013 Report Posted May 22, 2013 id like to know what different trans gearing he has. Quote
tdod101 Posted May 22, 2013 Author Report Posted May 22, 2013 Vforce 4 reeds Toomey t5 pipes and silencers K&n filter pods ( obviously no air box) Jetting is perfect 40:1 fuel ratio Quote
tdod101 Posted May 22, 2013 Author Report Posted May 22, 2013 id like to know what different trans gearing he has. He won't tell 1 Quote
lms1977 Posted May 22, 2013 Report Posted May 22, 2013 im sure his trans gearing is stock.. and if your motor is stock with bolt ons its not 60-63hp Quote
tdod101 Posted May 22, 2013 Author Report Posted May 22, 2013 He has NO bolt on mods though, he's even rock'n stock pipes Quote
lms1977 Posted May 22, 2013 Report Posted May 22, 2013 He won't tell he is lieing to you he might have a over ride or cut trans but the ratio is stock... Quote
lms1977 Posted May 22, 2013 Report Posted May 22, 2013 He has NO bolt on mods though, he's even rock'n stock pipes well then you just suck I guess.. sorry 1 Quote
special06shee Posted May 22, 2013 Report Posted May 22, 2013 Your quad is a complete turd if this is the case. Sorry and im not being a dick, but id look real hard into your bike. There is most certainly a problem with your quad Quote
lms1977 Posted May 22, 2013 Report Posted May 22, 2013 if your tapped out in 6th and get passed I could see that cause your gearing but if a stock shee is smoking you there are some issues Quote
tdod101 Posted May 22, 2013 Author Report Posted May 22, 2013 he is lieing to you he might have a over ride or cut trans but the ratio is stock... Why do you think the ratio is stock ? Quote
