Coty23 Posted May 20, 2013 Report Posted May 20, 2013 Im in need of 4mil cases for cub thats been drag ported. Let me know what you have Quote
Coty23 Posted May 20, 2013 Author Report Posted May 20, 2013 Yea i guess. Looking some that's been match to cub cylinders Quote
quadpro26 Posted May 21, 2013 Report Posted May 21, 2013 i have a set of polished ones that are setup for a cub (no chain wack) $265 shipped Quote
J-Madd Posted May 22, 2013 Report Posted May 22, 2013 It's easy to match them to cub cylinders. I would match my own if I were you. The casting could be different than someone else's or they may have opened up the transfers different. You can't get too much transfer area, IMO. But I'm no engine builder. If you go too far in stock cases though, the gasket sealing surface is thin. Quote
Deadbeat Posted May 22, 2013 Report Posted May 22, 2013 It's easy to match them to cub cylinders. I would match my own if I were you. The casting could be different than someone else's or they may have opened up the transfers different. You can't get too much transfer area, IMO. But I'm no engine builder. If you go too far in stock cases though, the gasket sealing surface is thin. could you use a cub gasket as a template? Quote
J-Madd Posted May 22, 2013 Report Posted May 22, 2013 Most people do, but there may be room for improvement over just going by the gasket layout. Quote
Deadbeat Posted May 22, 2013 Report Posted May 22, 2013 Most people do, but there may be room for improvement over just going by the gasket layout. probably the difference between a good motor and a race winner, thanks Quote
