NYrider631 Posted May 14, 2013 Report Posted May 14, 2013 Considering this conversion, I ride a lot of trails and street. Im a decent mechanic. are J arms truly THAT bad? and would it be better to just get a new frame or do the conversion depending on how tough it is to do. Quote
blue97shee Posted May 14, 2013 Report Posted May 14, 2013 they tend to chew thru the upper arm bushings a bit faster than an a-arm, but thats not a huge deal. Quote
NYrider631 Posted May 14, 2013 Author Report Posted May 14, 2013 I hear they bend and break easily which didn't make much sense to me but Yamaha did stop using j arms and went to a arms so I just went with the rumors haha Quote
Starwriter Posted May 14, 2013 Report Posted May 14, 2013 J arm bikes have a lower street value because of the perceived weakness. I have come down nose first so hard in the sand, with a J arm bike, that I should be paralized, and I didn't bend a J arm. I've seen plenty of bent stock upper A arms, J arms, and frames. Hit a tree hard enough and somethings gonna bend. If you wanna convert it, find someone with a junk A arm frame, cut out the angled tube with the rear A arm bracket, and weld it in. Quote
lms1977 Posted May 14, 2013 Report Posted May 14, 2013 unless you wanted to make it wide I would just use the j arm frame and arms as is Quote
