Hey guys, im in the process of collecting parts to finish my Banshee. I dont have the money to purchase everything at once right now, but I will be buying things a little at a time. I'm starting a new job Monday and if all goes well, things will start to move a bit faster. I'm just going to post everything I need once so I dont have a gazillion page thread about what I need. Aint nobody got time for that...So here goes....PM me or post away if you have anything.
Front Spindles. New style preferred but not necessary.
Front Calipers and mounts...must match spindles obviously.
Front Master Cylinder/lever.
Aftermarket Front Bumper. AC racing preffered but lemme know. Dont gotta be blingy, im gonna PC it.
Grab Bar. Would like a PRM Baja style one, again gonna PC it most likely.
Front Pipe mounts, OEM or aftermarket, as long as theyre good.
Rear shock, not blown. Need upper and lower shock bolts also, i have the rest for the linkage.
Swingarm bolt and end caps
Stator. Square plug.
White OEM plastic. Must be nice, I'll buy Lakers if necessary. White tank and rad covers also
headlights. Flat plug.
Nerfs. Black or Blue nets.
OEM wheels, front and rear. Tires dont really matter. Any finish, again gonna PC
Lugnuts. Not a big deal, can buy them if needed.
Carbs. Stock with TORS removed or 28PWK's
Steering stem clamp, seals, and the special rad mount bolt
Aftermarket engine/trans stuff I want: Will probably end up buying new but I'll mention it just in case
Shift Pro
Pancake bearing
Billet water pump gear
Aluminum Radiator
Modded shift star
modded shift shaft
+2 arms
+1 or 2 antivibe stem
aftermarket front shocks...no elkas
stock length round carrier swingarm and carrier
aftermarket extended axle
Extended thumb throttle lever
Thanks for looking. I hope this isnt too big of a PITA for folks.
  • 4 weeks later...
  • 2 weeks later...
