I wondering if my timing is to crazy. I have a gray ground strap that's about an 1/8 inch from the end of the strap. It's not at the bend. My real question is which way does the timing mark move if u add more timing towards the end of the ground strap or towards where the strap is attached to the plug.
10 mil cub
Drag port
17cc domes
39mm Kehins
Vf3
CPI big bore
+7
What is your elevation?
If you're at or near sea level...I'd be very, very weary of adding too much timing on a 10 mil cub with 17cc domes.
Have you measured the cc of the domes?
Also, you may lose top end/MPH adding much more timing to a motor..
I've bumped timing to the point the ET remained the same but I lost MPH because the motor was fighting itself.
I ran +7 on my 10 mil with BB CPIs, 41pwks, 20 cc domes last year. Gonna try +8 this year on that motor. It was a little lazy to clean out, thinking that may help.
