akpopeye Posted October 29, 2003 Report Posted October 29, 2003 hey guys...how do i refinsih the outside of the cases of the motor...bead blast than laquer is what i hear...is that right...? what kind of laquer...also there is a small chip on the lower case, towards the inside of where the crank sits.....how do i know if it should be repaired..can it?? lata Quote
banshee370 Posted October 30, 2003 Report Posted October 30, 2003 hey guys...how do i refinsih the outside of the cases of the motor...bead blast than laquer is what i hear...is that right...? what kind of laquer...also there is a small chip on the lower case, towards the inside of where the crank sits.....how do i know if it should be repaired..can it??lata Do not use ANY lacquer based products... They will NOT hold up to the heat or any chemicals... (cleaning or fuel) I recommend beadblasting like you stated.. then clean VERY well with a solvent based cleaner (Prep solvents) Then apply either an Epoxy primer or an etch primer. (epoxy would be best) If you use an Epoxy primer then you can topcoat with either a bc/cc urethane or a single stage urethane. Stay away from Lacquers and Enamels. They will not hold up. As for the chip... post a pic of it and Im sure someone here can help you decide if its bad or not Quote
akpopeye Posted October 30, 2003 Author Report Posted October 30, 2003 thanx......is it best to brush this on...or how bout spray it on from a can..or do i need it sprayed with a gun...thanx again Quote
banshee370 Posted October 30, 2003 Report Posted October 30, 2003 thanx......is it best to brush this on...or how bout spray it on from a can..or do i need it sprayed with a gun...thanx again You can not brush any of those products on. I also dont believe you can get them in a spray can either. They are all activated w/ catalyst. This makes them cure/harden. I would look into having the cases powdercoated. It may be more cost effective for you if you dont have access to spray guns and other necessary tools/equipment. Quote
