Im assuming some billets. The 26-35 mm intakes take a 60mm spread bolt pattern and the larger sized take a 70mm spread bolt pattern. So no, you can't put smaller boots on the 70mm spread ones unless they're the 60mm spread ones.
On my Pro design billet intakes i went from stock carbs to 30's to 35's all on the same intake, just bought new rubbers once, as they're the 60mm spread ones.
Those are 70mm spread from where the middle of the bolts for the rubber boots bolt into the aluminum. So no you can't put the smaller 60mm bolt spread ones on.
This has nothing to do with how they bolt onto the Cylinders.
Here is a link to the sizes man. Check it... http://www.bansheedepot.com/proddetail.asp?prod=22-5805
that figures... I'm sure somebody will want to trade up (or do I keep them for when I trade up????)
do you know who makes them??
I would just put them up for sale or trade and get what you need.
they could be whiteknuckles ?
Agreed.
