Any one with a round house Carrier have a hard time moving it to adjust the chain?. My 35 mm was hard as hell to move when trying to adjusting the chain. Now my new 40 mm is just as hard..Just want to see if anyone else is having this problem.
It's the caliper plate binding up and not sliding while you're trying to twist the carrier,grab the caliper with one hand and rock it while twisting to adjust. Or a little grease on that slide/locater on the swingarm. Coupelx mentioned tightening in the direction the chain spins, seemed to work for me, to not come loose while riding.
It is probably the swingarm. As mentioned, its the nub that the brake caliper bracket slides on as the chain is adjusted. You sometimes have to grind that caliper slot open a little.
Yea u guys are right, it was the swing arm. I bought a new one today anyways need a longer arm. But Thanks for the help guys.
