I have burgaurd +2+1 A arms on my banshee and I need new bushings and a couple sleeves. I have left messages for burgard and I never get a call back. The bushing that were in these were a rubber busing. The problem is that the inside diameter of the arm is smaller than the stock bushing and the sleeves that they use are also smaller in diameter. I found 3/4 brass bushings at the local hardware store that fit the arms perfect, but I cannot find anything that will work for the sleeves. I could possible drill out the bushings to accept the stock sleeves. Anyone know who I can get a set of sleeves from?
The reason I posted it here was because I checked with different companies and it seems that these arms use different size bushings and sleeves that any other arm on the market. I figured that someone may have run across this problem before. I guess I will have to find a machine shop that can turned down a stock set of sleeves to fit the bushings.
If you cant find a machine shop that wants to mess with it. i could do either option for you, either turn the stock bushings or ream the brass bushings out.
