Wanna get rid if the key switch, I have 4 wires connected to the switch, brown red with and black. If you go down the line a little you can only see two wires Black and Red that connect to te rest of the electrical. What do I do ?
Un plug. on the harness side splice the 2 together, done.
Red with black stripe and black? I don't remember
That's what in sayin, there four there
Follow the key switch down. Un plug it from the harness. Throw it in the trash, now on the harness side of the plug it will be 2 wire red with a black stripe and black. Connect them
You're missing the point. 2 of the wires from the key switch to the connector don't do anything and aren't connected to anything. After you remove the key switch from the bike, you will only see 2 wires in the harness. red/black and black. Connect them together and ride.
Ohhhh okay. So the red and black wire from the actually key switch get connected to the other black one that's connected to the plug. I see
Ignore the colors on the key switch side of the connector. They're all jacked up. Remove the key switch with connector and connect the harness wires as previously mentioned.
am I explaining it wrong?
