Hey fellas got a polished 535 cheetah top end(complete)
Cylinders ported by WK racing. Comes with reeds,39mm intakes,pistons,base gasket,domes,head, and all hardware-1000shipped
10mil crank works crank(115mm rod) Has max load and tz bearing. Great shape maybe 20hrs on it if that-650shipped
Brand new Hinson basket with cushions-140shipped
I'll get pics of everything later tonight
1. Oem basket(tight),pressure plate,hub(not pictured),oem springs,pusher-65shipped
5055F1D4-57D8-4FFB-9951-26B2DA268C73-481
7DA232CB-48AD-4543-BCD5-FC34E37DE3A2-481
E3E73247-92C7-4ECC-BE10-824F2FFCF288-481
2. Oem stator from a 99-75shipped
FCEF816B-EBBA-4F9B-B5F8-FB3C771DC444-481
CA95F587-9D1E-44AE-8A02-89ABABF8C1AC-481
3.brand new Hinson billet basket & cushions-140shipped
92A85E2F-4C40-4F8F-99A2-E64F266E25E7-481
C6E7507B-AF1E-4B45-A5BB-7AA92CB506CE-481
85BFF5FC-76BA-4582-8DB5-CDC36DB6B546-481
54607593-D467-42C0-8C2D-7A92FEC17890-481
4. Set of 39pws's (gas)-325shipped
7ED41DC4-D27C-4F55-B24E-D21534FF08F4-481
69F32891-0889-4D18-8890-90B1C5DC169A-481
5.oem clutch cover(complete) with water pump & cover,insert,dipstick,hardware-40shipped
863565AC-0B97-49F6-9F3A-6BA957D86285-481
BAEE18F1-1C41-4428-BEC6-F372EC55B87B-481
6.complete stock trans(complete) drum,forks,gears,shaft,spring,boss,etc..-110shipped
1537BD0B-9719-4F32-99F7-5563B31B25CE-481
7.polished/ported WK racing 535 cheetah topend(head,cylinders,domes,upp intakes,reeds,pistons,.031 base gasket,block off plates,hardware, & cases bored&ported to the 535 cylinders-1400shipped
507C8F4C-5F75-4385-B203-80939D1CCC9D-481
3208C614-CF0D-4CA2-8D19-E81519082494-481
2E6B2DAD-FEA0-4763-B517-D403E1D2CBB1-481
B7078D7A-C03C-4C1A-98CD-BE2D9F5D52D8-481
80AA9CCD-EB0E-4039-9733-D7FE5BD6210E-481
61994F4B-AC0C-46E7-9A62-76E24AF91D18-481
72AB872C-0651-48AB-97B4-557FE9712D33-481
66BB332E-B61F-4177-B2E6-E11625705A77-481
7967F7D6-571C-4641-80FA-B5E0FFB7C663-481
D2B6E0FF-A0E4-46F8-BB73-1CBD92EBF260-481
27840AA8-7A60-415A-86D5-A51C302463B8-481
ED4B599D-25EB-4AC3-840C-1D7E60AE7B70-481
Crank works 10mil crank with maxload & tz bearing. Also trued & welded. Has 20hrs if that on it. 115mm rods-650shipped
8819F5C1-C6F1-4EBF-8623-0FAFDDBFE4C4-452
8AE0F052-B9AD-4502-8CF9-A7D6A7E6AB2E-452
0706F4DD-2811-4DD6-BAC0-BF49DC7FCB9C-452
E6E81D38-7FF6-4133-9B49-F3EA29AA5C7B-452
27947B96-030E-47AF-BD81-65B76C19DC64-452
It really looks like an iron sleeve in those cylinders to me!!
crazycracker
after actually looking at the pics on my computer instead of the phone, those do appear to have steel sleeves...
could be the pics still but see if a magnet sticks to the cylinder walls.
Cylinders are ready to run! It's just the pics that make it look that way brotha
Are you sure? Would you know the difference? Put a magnet in them! Every picture shows a line!
i just pulled a magnet off the fridge to see if it wud stick to the inside wall of the cylinder and it didn't. I bought these from a member who had got them from another very reputable member on here. so I know there should not b any problems with em at all.
