speedster07 Posted October 23, 2003 Report Share Posted October 23, 2003 what is the safe way to dissconnect the throttle overide on a banshee? also what is the module that is mounted right beneath the flywheel? Quote Link to comment Share on other sites More sharing options...
Scott M Posted October 23, 2003 Report Share Posted October 23, 2003 the TORS "brain box" is under the gas tank mounted to the frame by the left expansion chamber. It's about a 1" cube w/a 3 prong plug, disconnect and seal the plug w/silicone to deactivate. There are 3 other switches which may or maynot cause probblems. I have detailed instructions on them and complete TORS removal if you want them shoot me a PM. @ the bottom of the flywheel is a pick-up coil, it should be spaced .030" from a node. Read on and Ride Hard! Scott []v[] Quote Link to comment Share on other sites More sharing options...
