smurph317 Posted April 7, 2013 Report Posted April 7, 2013 I have a 98 banshee . I tore it down to replace shifting forks . And during my repair i found my side to side rod clearance was excessive (.057") . So it's time to replace the crank . I was curious about a stroker crank but I'm not familiar with all the ins & outs . Do I just throw a stroker crank on and that's it. ? Do I need to do any cylinder work ? Do I have to worry about anything else ? I just shaved .030" off my head to increase my compression and bought a 2 into 1 intake with a 34 mm carb . And an adjustable stator plate . Any input would be great Quote
vulvafan537240 Posted April 8, 2013 Report Posted April 8, 2013 Have the jugs ported for the stroker crank and stroker pistons and have the head machines for the crank or a cool head with stroker domes. Quote
smurph317 Posted April 8, 2013 Author Report Posted April 8, 2013 I have to do all that ?? Or is that just optional stuff ? I had my head shaved isn't that the same as domes ? Quote
vulvafan537240 Posted April 8, 2013 Report Posted April 8, 2013 You could use a spacer plate instead of the portwork but its not worth it. You would probably make more power with a stock stroke. You will 795 series pistons only if you get a long rod crank, (which I'd do). Shaving the head is not the same thing as stroker domes. You can machine the head to make the dome area "deeper" as the pistons will be 2mm higher at tdc now. Quote
sheerider11 Posted April 8, 2013 Report Posted April 8, 2013 I have to do all that ?? Or is that just optional stuff ? I had my head shaved isn't that the same as domes ? Just keep it stock if that is your response Quote
mopar1rules Posted April 9, 2013 Report Posted April 9, 2013 Just keep it stock if that is your response No kidding Quote
