Cylinders are Dune Ported by Herr Juggs racing. Noss coolhead with 21 CC domes for running pump gas. Hot Rods stock stroke long rod(115mm) crank, that was also trued and welded by HJR, Wiseco 795 series pistons that are made for the long rod setup. Cylinders were bored to 64.50 with new pistons and the crank was welded. Top end has 32 hours on it from fresh, you can still see crosshatch in the cylinders, however there is one vertical scratch that is very small above exhaust port that you can barely snag with a nail, it never effected compression or how it ran. This motor ran awesome and was right at 130 psi in both cylinders when torn down. Comes with everything in the picture(no coolhead orings or nuts).  $700 shipped.  for more info or more pics text 858-848-4621 -Aaron
580 shipped with gifted paypal, you wont be dissapointed with how these cylinders run.
