Well finally fired the bike on some methanol last night and the left cyl is not firing. Its getting fuel and spark. I am going to clean the carbs real good and swap sides and see if that changes anything. swapping plug wires didnt help or diff plugs so looking to see if any of you have any other suggestions. piston still looks like new and plug does also just a lil wet.
May want to use dedicated plugs. One set for alky and another for purge. I'm sure you already know that though :)
Troy
yeah for loose screws between your right ear and your left,   thought you had already tested the stator ?   Just my guess there is still something wrong even with a weak stator that will only fire one cylinder you should still be able to get the left cylinder running by leaving the wire off of the right side.
Start it, pull the cable up on the top of the carb on the side thats not firing and see if it picks up.  If no change, double check that the needles(metering rods) are infact in the right direction. Next, with the filter removed hit it with some starting fluid and see if it picks up. Report back
Did you ever try swapping carbs and did you further inspect the reeds,   All the smarter banshee folks seem to think my previous post is wrong but just seems there should be a way to make the left cylinder have the least resistance and fire if the right side is capable of firing unless they're  other problems
shit fire piss on the matches i may be redeemed lol , i know when checking my stuff it really hard to get an accurate reading from those bullet connectors
i dunno still has me concerned my stator on my vstar did the same thing last year one day it would work and test fine next day it wouldnt luckily it was under warranty still
