jcormode Posted March 19, 2013 Report Posted March 19, 2013 So after buying a banshee with a wrecked wiring loom, I bought a second hand stator, fly wheel, loom, cdi and coil from a 01 quad, It looks aside the key wires are permanently conected, I don't have a handlebar switch or tors or lights. I've earthed the coil and another wire that looks asive it should be earthed as it has a ring conector to bolt to something. The guy who I got it of has been very helpful and I have no reason to disbelieve him when he said it was working perfectly. Obviously I've got something not right somewhere as there's no spark what so ever. Do I need to wire anything together where the handle bar switch went? Is there some other wires that need joining etc. Cheers in advance lads Quote
BeeCanBanshee Posted March 19, 2013 Report Posted March 19, 2013 You need some sort of ignition switch. Either key or tether. Search on bhq for a wiring diagram or get a manual with one. And see what your missing. Also did you test the cdi,coil,plug wires,boots and stator? Quote
jcormode Posted March 19, 2013 Author Report Posted March 19, 2013 Still waiting for my mate to bring his tester round for that. I was under the impression that the switch / tether was a switch to earth out the live, not to create a circuit? I have been now'n to be wrong in the past though Quote
jcormode Posted March 20, 2013 Author Report Posted March 20, 2013 I can't get any volts from my stator or my friends stator that is off his working bike ARGH!!!! wtf am I doing wrong stator and flywheel conected, earth on black, no power from any other wires on both stators?!!!!! I'm right in saying 12 dc current?? Quote
joey83 Posted March 20, 2013 Report Posted March 20, 2013 Look at the book and check RESISTANCE. Not Volts DC. Get an ohm reading and compare it to the range in book. Then look at the wiring diagram and make sure you wired everything right. The diagram will show you what should open and what should be closed (tied together). Quote
BeeCanBanshee Posted March 20, 2013 Report Posted March 20, 2013 Check the 2 small wires coming off the stator should get CON. Quote
jcormode Posted March 20, 2013 Author Report Posted March 20, 2013 Bad earth I think? Tester didn't work and I had a bad earth mabe runs now but dies at low revs. Think I need to adjust the ignition timing on the Ricky's stator ? + or -????? Also do they have a thermastat as the barrel is warm but rad and water is stone cold? Thermastat or impeller I know the Tri z's are bad for impeller I know I've three lol Quote
BeeCanBanshee Posted March 20, 2013 Report Posted March 20, 2013 Ricky stators have probs. Get a OEM. Many people will say the same. Pull your buddies and throw it on yours. Quote
