b_a_n_s_h_e_e Posted October 19, 2003 Report Posted October 19, 2003 Hey all, I just installed a heavy duty clutch for the shee, but when I start the bike up pull in the clutch and put it in gear, the bike still moves forward like the clutch isn't all the way in. It is also very hard to shift through the gears. I don't think the clutch is disengaging (<--sp?) all the way. Is there some kind of adjustment, and if so what do I do? Thanks!!! Quote
00BANSHEE Posted October 19, 2003 Report Posted October 19, 2003 Mine acts the same way. I am gonna try to do some more adjusting. I'll post results here for you. Quote
b_a_n_s_h_e_e Posted October 19, 2003 Author Report Posted October 19, 2003 Thanks OOBANSHEE, does anyone else have this problem? Quote
sandman121383 Posted October 20, 2003 Report Posted October 20, 2003 hey man are u revvin it up when u put it in gear? uf so let the revs down b4 u drop it into 1st. also let it earm up a lil.mine wants 2 go when i put it in 1st w/o warmin it up enuff. but once i run her for awhile and i stop and restart it doesn't start creepin when i put it in gear. hope my insights helps a little Quote
_Nick_ Posted October 21, 2003 Report Posted October 21, 2003 I have the exact same problem this weekend. I believe it was not adjusted properly. I had to take of the clutch cover and adjust that screw on the pressure plate. I believe it fixed it. The clutch wasn't diseng. enough. We will see when i test it in glamis... Quote
87workshee Posted October 21, 2003 Report Posted October 21, 2003 I posted the same problem but I got it fixed. don't adjust it until its been warmed up for about 5 minutes or so then try it. trust me It will works 99% of the time. just let it idle rev it once in a while and it'll work. also I had an easy clutch system that was making the clutch only pull a few mm's. make sure you don't have one sitting at the end of your clutch perch. Quote
