Abdul Posted February 23, 2013 Report Posted February 23, 2013 Heey guys I am wondering what is the function of the reeds and the adjustable plate ??? I will be getting a adjustable plate and should I put the timing on 4+? Please do you have any video about how to install the reeds and the adjustable plate ? Thanks alot. Quote
sheerider11 Posted February 23, 2013 Report Posted February 23, 2013 Clymers tells you how to install reeds. Timing plate, you need a flywheel puller and take that off, unbolt the oem mounting plate( 3 bolts 10mm I believe) un bolt the stator from the plate, then work backwards with the adjustable plate. Once you get the stator back one and the plate loosely bolted on, use the split between the cases as you guide. Line that up with the +4, reinstall your flywheel torque it down, don't forget the woodruff key. Inspect it and make sure it's straight and everything lines up. Quote
Abdul Posted February 23, 2013 Author Report Posted February 23, 2013 Clymers tells you how to install reeds. Timing plate, you need a flywheel puller and take that off, unbolt the oem mounting plate( 3 bolts 10mm I believe) un bolt the stator from the plate, then work backwards with the adjustable plate. Once you get the stator back one and the plate loosely bolted on, use the split between the cases as you guide. Line that up with the +4, reinstall your flywheel torque it down, don't forget the woodruff key. Inspect it and make sure it's straight and everything lines up. thanks alot !! But can you explain what is the function of the reeds ? Quote
sheerider11 Posted February 23, 2013 Report Posted February 23, 2013 thanks alot !! But can you explain what is the function of the reeds ?As simply as I can put it is its a one way valve. Stops the charge from going back out the carbs. Quote
Abdul Posted February 23, 2013 Author Report Posted February 23, 2013 As simply as I can put it is its a one way valve. Stops the charge from going back out the carbs. thanks , should I get the v-force reeds ? Quote
