Hi, let me work through a few things.
Flywheel pickup gap set to .20?
What size pilots? 27.5 for a piped banshee or 25 stock.
Air screw set to give of take 1.5 turns. If you have stock pilots turn it to .5-.75 and see if that helps
Needle position in the middle?
Hope the information helps. If the pilot circuit is lean it won't start and will backfire but could be electrical.
