Hey guys ... I am looking to get the most out of my banshee this summer and need some help determining the best route to go.
I have:
Duncan High Rev Pipes
K&N Filter (no lid)
Milled Head .030 over
new Reeds
27.5 Pilot Jet
330 Main Jet
Bored Cylinders 10 over
New stock Pistons & Rings
Medium Port to match
110 Octance Fuel
Here are my questions:
1. With stock carbs ... Am I getting all the power I can out of my banshee?
2. Should I move to 30 or 34 mm carbs?  If so ... any recommendations on brand?  How will I benefit from the new carbs?
3. If I go up in Carbs ... will I be able to use the same Jets I use for the stock carb?  If so ... what Jetting should I use?
4. With the head milled .030 .... is that optimal?  With the high rev pipes I wasn't sure what the max milling should be?
5. I replaced the Reeds -- but should I have replaced the Reed Cages?  If so -- what will that dofor me?
Thanks guys!!
Mimi
mimi.....I would have to say that if youd go up to larger carbs you would gain some top end...however a lot of guys have said that they've noticed some slight drop off on the low end.
I do have to ask though.....any reason why your running 110 octane?  With a milled head and a port job you should be perfectly fine running just premium pump fuel.  Hell with my ported motor and a milled head I was running less compression than before I changed to smaller domes in a cool head......and im still on premium pump.
Where in Michigan are you at and where do you ride?  There's a lot of us on here that are from Michigan
Jereme
