re = racers edge.  i have a set on my cheetah.  not very often will you see a set for sale because most people, including myself, that find a set hang on to them forever.  i don't have any numbers or dyno proof for them, but tried them on 3 different cheetahs, from little to big, and they all seemed to benefit from the re pipes.
but, as dude said above, listen to what your builder says.
i would spend as little as possible on this set up. its a hard motor to get running good i hear,get as much as u can for people on hq like lock up, over ride and save money
If wild card is setting it up I would ask him what pipes would work best with the dome design it has and the port work done to them... I have always had good luck with wcr trannys... Go with 39 pwks or 40mm lectrons, fast clutch, billet basket, stock pressure plate and hub, direct drive lock up.
This isn't cfhs old motor is it?
Yes this was his motor. Why do you ask?
no reason.... motor has gone through like 3 or 4 people and still hasnt been run lol wonderin if anyone's ever gonna run it
Yes I will be running it. Just need a few more things and I'll be good to go. Planning on having it done by the time weather breaks.
