4strokekiller12 Posted January 30, 2013 Report Posted January 30, 2013 160 compression 35airstrykers 4mill longrod stock cages boyseen reeds rdz silenced drag pipessb is this a good setup for these pipes Quote
trickedcarbine Posted January 31, 2013 Report Posted January 31, 2013 Pretty close. I assume it's a drag bike. If it were me, I would ditch the strykers in favor of a set of normal PWK. Maybe even go a little bigger. Port your stock cages or get some VF2 or VF4 reeds. Those pipes will get the heat moving a little nicer to with some timing as well. What kind of domes are in there? Quote
4strokekiller12 Posted February 2, 2013 Author Report Posted February 2, 2013 stock head made for 4 mill will I gain any thing with different pipes Quote
trickedcarbine Posted February 3, 2013 Report Posted February 3, 2013 Not much if anything. The RDZ pipes are pretty well done. Quote
4strokekiller12 Posted February 10, 2013 Author Report Posted February 10, 2013 thank you what should be good gearing 22 13 paddle gliders went from 8 haulers Quote
trickedcarbine Posted February 11, 2013 Report Posted February 11, 2013 You just drag racing it? Quote
4strokekiller12 Posted February 15, 2013 Author Report Posted February 15, 2013 pretty much unless driving it out through dunes Quote
trickedcarbine Posted February 15, 2013 Report Posted February 15, 2013 14-42,43 or even 13-42,43 Quote
4strokekiller12 Posted February 15, 2013 Author Report Posted February 15, 2013 anyone have a 43 steel Quote
