Hey guys,
In the middle of my 4mil build, so I'm trying to offset the cost by getting rid of parts I no longer need/want.
PICTURES (with exception of crank) WILL BE ADDED BY TOMORROW NIGHT, fyi.
All the stuff listed came off my 99 running bike- only making room for the new gofast stuff  :banana:
2 sets of stock Mikuni carbs: No TORS. One set has the idle kit installed. The other the PO had tried to make his own idle screws but gave up. Both sets run perfect. Will include the thumb throttle cable, a few jets/gaskets/needles, and airbox boots if needed.
Stock head: Head in great condition, no major pitting. Plug threads are perfect, and will include the head gasket.
Stock clutch: Basket, hub, PP, metal plates, and hardware. I won't include the fibers as I believe they're worn to crap.
Stock airbox: Airbox with Proflow plate and used K&N filter. I'll clean the filter right before I ship.
Stock crank: Nothing wrong with it- just replacing with 4mil crank. I may need verification if this is direct OEM or aftermaket once I get it out of the cases. Will include seals (no leaks AFAIK) and bearings.
Pistons: 65.00 Pistons. I wanna say they're Wiseco, but I need to get them out on my bench to verify. Will include rings, wristpins, circlips, etc.
Electrical: Headlights with grille removed; headlight/kill assembly
Not quite sure what any of this stock stuff is worth, so shoot me offers/trades. Below I'll list what I'm interested in:
35mm PWKs- intakes, pods, throttle cable setup
Black coolhead (NOSS, FAST, Modquad)
MAKE OFFERS
Shipping from 11727 (NY)
  • 4 weeks later...
