ONLY2STROKES Posted January 7, 2013 Report Posted January 7, 2013 can someone tell me approximately how many lbs of powdercoat it will take to coat a ridged 90" WB ridged drag chassis? frame only, the bar and steering will be a different color. Quote
So Cal Suspension Posted January 7, 2013 Report Posted January 7, 2013 1lb or less. Always buy a little more than double what you need in case you screw it up and have to re-do it. Quote
ONLY2STROKES Posted January 8, 2013 Author Report Posted January 8, 2013 wow i though it would take alot more. im having a shop my bud works at do it. he does not work in that dept. so he wasnt sure. they do not have custom colors on hand so i was going to get the powder. he told me at least 5lbs. not saying you arent right, but are you certain it will take no more than 2lbs? Quote
So Cal Suspension Posted January 8, 2013 Report Posted January 8, 2013 A lb of powder goes a LONG way... If he's doing the powder, do what he suggests, but I know I've done stock banshee frames with about half a pound. One pound of powder would cover about 60-70 square feet. Quote
ONLY2STROKES Posted January 8, 2013 Author Report Posted January 8, 2013 A lb of powder goes a LONG way... If he's doing the powder, do what he suggests, but I know I've done stock banshee frames with about half a pound. One pound of powder would cover about 60-70 square feet. great! thanks alot! Quote
Paulie B Posted January 8, 2013 Report Posted January 8, 2013 Whoever is doing it must have a big ass oven! Quote
fappy'97 Posted January 8, 2013 Report Posted January 8, 2013 Yup, I agree with Matt, under 1lb per color. If you're doing a primer, base, translucent, then clear, it would probably be a little over 3lbs.... Quote
Coupelx Posted January 8, 2013 Report Posted January 8, 2013 I did 4 wheels a valve cover and dozens of little brackets with a pound and ststill have some left Quote
ONLY2STROKES Posted January 8, 2013 Author Report Posted January 8, 2013 Whoever is doing it must have a big ass oven! they do paulie, they build cranes and sh*t! Yup, I agree with Matt, under 1lb per color. If you're doing a primer, base, translucent, then clear, it would probably be a little over 3lbs.... thanks! I did 4 wheels a valve cover and dozens of little brackets with a pound and ststill have some left thanks! Quote
Stimbert Posted January 11, 2013 Report Posted January 11, 2013 I just did my 114" heavily braced rigid with a little less than 2lbs. Quote
ONLY2STROKES Posted January 11, 2013 Author Report Posted January 11, 2013 I just did my 114" heavily braced rigid with a little less than 2lbs. thanks for the information! Quote
