hi guys i want to start working on my banshee for off road round tracks terrain use i need help building it though i really do not know what to buy im looking for advice i have $5000 to spend atm i don't know what shocks carbs reeds bore axle a arms etc to get would appreciate it if someone could help me with a list of parts to build it thanks
New sunstar sprockets and did 520 chain
"Dead man" kill switch
All round shock covers
New disc's & pads
New rear Dunlop tyres
Almost new front Dunlop tyres
New Wheel bearings
New A arm sleeves and thrust caps
Alloy nudge bar
Recon rad
New green rad asi performance hoses
New dual in line auxiliary coolant coolers
New monster energy GRN Graphics
New powermadd hand guards
New powermadd extensions
New powermadd swivel mirrors
Alloy nerf bars, re netted
New carbon fibre frame guards
New flywheel cover
New Carb needles, jets, hoses
Dual Pro circuit platinum head pipes
Dual fmf back boxes
Wiring loom overhaul
New spark plugs
New heavy duty tie bars with ball joints
New exhaust o-ring gaskets and springs
New tusk clutch cable
New CFM performance air box (6 - 10HP Increase) Item Number:380466900551
New twin uni air filters
New rear swing arm needle bearings, sleeve and thrust caps
New rear suspension link arm bearing overhaul
New chain slider, guides and rollers
New axle housing bearings
New chain adjusters
New Nstyle seat cover
New kick starter rebuild kit
New Tusk racing billet aluminium fuel cap
New Pro taper fat bar clamps
New MSR motion fat bars
New MSR grips and donuts
New Clutch lever
current stuff i got done
suggest to paint the whole chassis while your at that stage of a teardown. I'm kinda in a similar situation - Trying to figure out what to replace but my budget is in the hundreds.
If your going to go with the stock carburetors - get a Tors eliminator kit. It cleans up under your seat and gives you more room to route stuff, and simplifies  sync + idle.
I think I'm going to relocate my overflow to up front like this kit (  http://jdscustoms.com/Yamaha_Banshee_Coolant_Bottle_Brackets.htm ) I will make it myself because I want to locate it a little differently - but there is a kit if you want to do it their way.  If your re-routing /redoing your Loom / Wiring, why not?!
I suppose you would need a better suspension over the stock suspension.
Elka shocks, some lsr (or comparable) +2+1 a-arms, roundhouse swingarm/carrier, lsr axle, pwk carbs, vf3/vf4 reeds, cool head and domes, advance timing, some good port work, hot rods crank, and that will be a great starting point
